Heat Tint On Duplex Stainless Steel
I am working on a project which utilizes 2205 duplex stainless steel, my question involves heat tint. Most literature I have read on the subject specifies that heat tint must be removed from welds that are exposed to the process fluid. However, experienced and successful fabricators have indicated that this is not an issue, they do not remove the heat tint and they have not had any problems with environmental cracking or crevice corrosion. I would appreciate any comments on this topic and as well as any experience with heat tint on 2205 duplex stainless steel.
RE: Heat Tint On Duplex Stainless Steel
Furthermore, a non-annealed weld is intrinsically inferior to the base metal. EdStainless( I'm sure he will have some valuable input) and I might disagree on the mechanism, there is as yet no generally accepted theory for why it is true, but the weld metal is inferior in pitting resistance without a homogenizing thermo-mechanical treatment.
Not having had any problems is a lame technical qualification for omitting weld cleaning and passivation.
If we are tlking about a light straw or yellowish color then it probably doesn't matter.
If the scale is darker (brown blue black) and not shinney (transparent) then it needs to come off.
They can pickle to remove it. Or grind, using fresh media, and then passivate. No polishing allowed. This will just smear the metal around and buff the oxide. It will look nice but not help corrosion resistance.
Take coupons from weld trials and have G-48s run on them. I would expect to loose 5-8 C just due to the welds. If you are using the correct over-alloyed filler you can minimize this.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Does your process require the ultimate corrosion resistance?
If there is some corrosion to 2205 by the process will it take care of the heat tint? There are degrees of heat tint.
2205 is not the easiest material to pickle, it requires a more agressive pickling medium than used on the 300 series SS. This may require mechanical cleaning with iron free media and then pickling.
Use the cleanest welding process for fabrication. 2205 SS is a material that doesn’t tolerate sloppy welding practices well.
Fabrication of 2205 takes more up front planning if your process requires that the material be pickled. How will you get to the inside?
Here is some information on welding and pickling 2205 SS
http://www.outokumpu.com/pages/Page____10027.aspx
1. I agree that not having problems in the past is not a sound definitive basis for approving a fabrication technique, but I also think that some credit should be given for the past successes of a fabricator. Though the technique is not specifically detailed, they are successful.
2. The heat tint I have observed is typically a black brown color, approximately 3/16" wide in the HAZ of the base metal. One proposal is to sandblast the welds instead of pickle/passivation, is this an effective approach?
3. All weld procedures and qualifications are sound and meet all testing as well as the published requirements of major suppliers (e.g. Sandvik, etc..). If the heat tint sections pass the corrosion test as specified in ASTM A923, would this be an acceptable measure of the fabrication quality?
alloy2205
Blasting can be problematic. I have seen two papers recently that indicate that a properly blasted surface isn't too bad. But no where near pickled. It is better than a bad grinding job.
I don't like dark, dull scale for many reasons. The problem with 'it has worked before' is that you have no documentation on the exact condition before. Is this the same? better? worse? There is no way to tell.
Michael McGuire
http://stainlesssteelforengineers.blogspot.com/
