Generator Connections
I have a 11.5kw generator from the USA. Voltage 120/240 -60Hz.
(3 wire)
Our utility company supplies a 2 wire 240v single phase -60hz. One line is established neutral (0v) the other live (240v)
All my equipment is 240v single phase.
I also have a automatic transfer switch.
Should i connect generator neutral to mains neutral. Or should I wire for two seperately derived systems.
Appreciate a response
Paget
(3 wire)
Paget
RE: Generator Connections
Are you suggesting that some cannot be rewired. Or if I have the expertise to rewire generators.
ONAN CMSD10
htt
I will try and contact the manufacturer regarding your suggestion.
Thanks much for advice.
Paget
You do not need to rewire the generator.
But I have a question where do you have 240V, 60Hz L-N system?
Understand you clearly alehman. I will get reply from company tomorrow and inform accordingly. Thanks again
Pag
