Stainless Steel on Brass
We have a stainless steel rod that goes into a brass hole. We need to investigate the friction that takes place. Could galling be a factor here? I understand that stainless steel has galling problems when used with some metals. The parts are heated up to a temperature of 400-500 degrees F when they are connected also.
RE: Stainless Steel on Brass
Need more information to answer your question;
 - list the specific grades of brass and stainless steel
 - what type of clearance
 - loads in service, static or rotating
 - environment
303 SS and B16 Brass
approximately 0.0077
transverse (up and down sliding)
- environment
dry/lubricated with mineral oil
In sliding wear, it would be desirable to have a harder material sliding against a softer material with lubrication. I would recommend using a cold drawn AISI Type 303 stainless steel rod. Cold drawing will increase the surface hardness and strength over annealed AISI type 303 SS.
