Lisp help needed.
Lisp help needed.
Lisp help needed.
Can you find anything wrong with this lip routine?
;WELD1.LSP
;Program to draw leaders and insert weld symbols
(Defun C:WELD1 (/ scale asz p1 p2 blipsav orthosav layersav)
  (setvar "cmdecho" 0)
  (setvar "attdia" 0)
  (setvar "blipmode" 0)
  (setq orthosav (getvar "orthomode"))
   (setvar "orthomode" 0)
  (command "layer" "S" "dim" "")
  (setq SCALE (getvar "ltscale")
        ASZ (* 0.18 SCALE)
        P1 (getpoint "\nLeader Start")
        P2 (getpoint P1 "\nLeader end"))
 (setsym)
 (setq symtest (findfile (strcat symbol ".DWG")))
 (if symtest
   (progn
      (command "line" P1 P2 "")
      (command "insert" "arrow" P1 scale "" (/ (* (angle P1 P2) 180.0) pi))
      (command "insert" symbol P2 scale "" 0)
      (prompt "\n *ERROR*  Invalid Symbol Name ")
 (setvar "orthomode" orthosav)
 (setvar "cmdecho" 1)
 (setvar "attdia" 1)
 (princ)
(defun setsym ()
 (setq symbol (strcat "w" wtype wside whand)
       spacing (getstring "\n Include length/spacing? <N> "))
       (if (/= spacing "") (setq symbol (strcat symbol "c")))
       (if (= wside "B")
        (progn
         (setq stagger (getstring "\n Stagger Welds? <N> "))
         (if (/= "" stagger) (setq symbol (strcat symbol "s")))
