Help with Autocad 3d modelling error?
Hi
Does anyone know what this error means:
"Modeling Operation Error:
 Coincident face_face_ints with different body vertices."
I seem to be getting this in my 3d models & I'm not sure why?  I'm running Autocad 2004 with Cadworx 2005 (piping &  steel program).
Thanks!
Lee
RE: Help with Autocad 3d modelling error?
bold
Hi
bold"Modeling Operation Error:
Thanks!
Lee
From Autodesk...
Issue
The following error occurs after importing a step file using the STEPIN command:
Note: This procedure may take a long time to complete.
   1. Use the EXPLODE command to convert the part to an AutoCAD 3D solid.
   2. On the command line, type amstitch and press ENTER.
   3. Select the 3D solid.
   4. In the Surface Stitching dialog box, under Stitch Type, select Custom Stitching.
   5. In the Operation area, select Heal gaps.
   6. Choose OK.
"Everybody is ignorant, only on different subjects." — Will Rogers
Hi Borgunit,
Thanks for help, but those commands that you have to me to use seem to not work?  it just say's "unknown command" ?
maybe you have a different version of autocad?
I currently have 2004 version?
Lee
I apologize, you would need to have the import add ons or have AutoCAD Mechanical to see those commands.
oh.. i see...   do you know where can i get the add ons from? for that command to work?  something tells me i might be beat on this one!!
Lee
