security for buried tubes
Hi!
Did someone already hear to speak in the technical means, of a procedure of covering the tube, after some embankment centimeters, with a cheap mesh of expanded plastic?.
Its usefulness for example, to Protect the sought tube, of an accidental excavation, even when you know about its exact position, because you find the plastic first. This mesh, alert the operator of the machine of its proximity.
My interest, if you can help me, it is to know the technical term for its description, and it seeks of a maker, if exists.
Aldo Passalacqua, eng.
RE: security for buried tubes
try USA bluebook 800 548 1234. Burial warning tape
Thank you Rosebud
I had try to make contact with some industry I found in the yahoo search and do not received any return. Do you know some industry to make contact?
I wil need some samples of this material and more especifications. There are some clientes mine very interested.
Aldo Passalacqua
Here is a sample specification for warning tape
PLASTIC MARKING TAPE
Plastic marking tape shall be acid and alkali-resistant polyethylene film, 6 inches wide with minimum thickness of 0.004 inch. Tape shall have a minimum strength of 1750 psi lengthwise and 1500 psi crosswise. The tape shall be manufactured with integral wires, foil backing or other means to enable detection by a metal detector when the tape is buried up to 3 feet deep. The tape shall be of a type specifically manufactured for marking and locating underground utilities. The metallic core of the tape shall be encased in a protective jacket or provided with other means to protect it from corrosion. Tape color shall be as specified in TABLE 1 and shall bear a continuous printed inscription describing the specific utility.
TABLE 1. TAPE COLOR
Color Utility
Red Electric
Yellow Gas, Oil, Dangerous Materials
Orange Telephone, Telegraph, Television, Police, Fire Communications
Blue Water Systems
Green Sewer Systems
Warning tapes shall be installed directly above the pipe, at a depth of 18 inches below finished grade unless otherwise shown.
