Thread not removed
Thread not removed
Thread not removed
Hi! I have here problem like this: M3.0 (3.000000) Diameter Hole1 has thread that does not dissapear after chaging hole type. I mean - I created simple hole with Hole wizard (M3.0) that now has thread!!!???
RE: Thread not removed
I forgot to mention, that this thread is'nt in the feature tree - you don't find it under M3.0 diameter hole as subfeature!!!
Is this a Cosmetic thread or thread texture?
What version of SW?
& all the best.
To CorBlimeyLimey. It's a thread texture and SW version is 2005.
So just to clarify ... you originally made a M3 tapped hole, then you changed it to a simple Ø3mm hole but the thread texture is still showing?
I don't have SW2005, but in SW2004 the texture can be removed by RMB on the textured surface, select Properties > Face properties > Remove color > OK
I was hoping that would have been fixed in SW2005.
& all the best.
Yes, originally I made tapped hole... But thanks - RMB was a good idea!
