2 speed gear reducer/transmission
Hi, I have been looking for and cant find a 2 speed transmission (1:1 & 1.44ish:1) that can handle 0-6K RPM, ~220 lb/ft (250 HP), fwd & rev operation. Ratio changes will NOT be under load, only stopped. Max O.A.L. < 25".
This is ultimately running a centrifugal compressor.
Any and all info is greatly appreciated.
Thanks!!!
RE: 2 speed gear reducer/transmission
Here is one that I have seen in use, but have no idea of the utility.
http://www.drive-all.com
