Discontinued ASTMs
Discontinued ASTMs
Discontinued ASTMs
Is there any general path to follow in specifying material when an ASTM has been cancelled without substitution?  Some manufacturers continue making material to a cancelled spec, like for example, ASTM A569.  Even though the material is available, I am reluctant to specify its use since ASTM A569 has been discontinued.  But since no substitution was provided by the cancellation notice I am  not sure what to specifiy for commercial quality hot rolled steel sheet.  I don't want to specify something that will be hard to obtain for a non-critical application.
I would appreciate any thoughts, in general, on use of cancelled ASTM specs and more specifically, substitutions for ASTM A569.
RE: Discontinued ASTMs
You could try looking through the AMS specs.  There are a lot of metal material specs that they cover.
Heidi,
Fairly often when a specification is discontinued, it is because of overlap with another specification.  Though there might not be a direct substitution, look for similar, comparable specifications or consolidations of specifications.
A569 was replaced by A1011.
Dear Heidi,
Pls. log on to www.astm.org and go to "individual standards'", here yu'll find the complete list of "Discontinued standards " alongwith the substitution for it. very helpful for yu, just check in..
Satish
