Flow thru the Vacuum pump
Hello
I need to calculate the flow through the vacuum pump which pulls air out of the condenser to keep the vacuum for the unit. Can anybody help me with this?
Right now, we are using the flow meter and taking reading inch by inch across the diameter of the pipe and the average value times area of the pipe gives us the average flow thru the pipe. But, we are getting some erroneous values recently. So, I was wondering if anybody knows of any other test that can be done online to test the flow thru the pump
Thanks in advance
Thanks in advance
RE: Flow thru the Vacuum pump
I understand you are averaging from inch to inch. However, one of the the most common ways to measure flow at the traversing stations is to divide the pipe into a number of equal areas taking measurements at their centroid.
The location of the measuring points, as r/D distances from center, are tabulated herebelow:
3 points/radius 0.204, 0.353, 0.457
4 points/radius 0.177, 0.306, 0.395, 0.468
5 points/radius 0.158, 0.274, 0.354, 0.418, 0.474
6 points/radius 0.144, 0.250, 0.323, 0.382, 0.433, 0.479
Taken over two perpendicular diameters.
There are other methods of locating the probes.
There are, as well, anemometers such as the hot wire, or ultrasonic.
Besides, can you measure the discharged air from the vacuum pump ?
Have a look at Fan Engineering by the Buffalo Forge Company (Buffalo, New York), for the subject of measuring air flows.
HEI gives some ranges of air leakage to be expected on given sizes of condensers with respect to exhaust flow rate, turbine openings, etc.
rmw
