hole callouts with fits stacked on SW2005 SP0.1
HI, I have a problem in my SW 2005 SP 0.1.  When I put a hole callout in a drawing it looks right, but when I try to add some tolerances (a fit for a dowel pin, for example) the symbol of the depth and the fit, overrides.  I mean, I have the  (for example) H7 just in the same place that the arrow.  It's like SW does not give enough space between the diameter and the depth symbol to fit the tolerance.  Does anybody know something abuot this?  By the way, I modify some lines in the calloutformat, but this is happen even with the lines that I don't change.
THanks for your help!
Adi Corrales Magallanes
Centro de Ingenieria y Desarrollo Industrial
Queretaro, Mexico
