Tooling vs. grinding forces - How to predict?
How can the forces be calculated to determine how robust the workholding tooling should be designed?
RE: Tooling vs. grinding forces - How to predict?
? Maximum unit horsepower:  30 hp / ( in 3 / min )
? Wheel speed,  vw        8200 ft / min
? Width of cut,  wc     1.250 in  (actual surface:2.855 in )
? Feed rate,  vt    3 in / min
? Depth of cut,  Dc     0.056 in
? Wheel diameter    16 in
? Force exerted by the magnetic chuck    45 lbf / in2
