Relative View and Round stock!
I have been using relative view for awhile now, and whenever i come to a piece on my assembly that has no straight edges (ie, round bar, or a shaft), i cant import that piece into a drawing without draging in the whole assembly.  I can pick the 'cut-off' surface of the shaft for the "first" surface, but SW wont let me select the "second" surface to complete the selection. Is this a known bug???
PJ
RE: Relative View and Round stock!
Yeah, I have this problem, too.
Usually, I just orient the model to the end view (select theend face and click the "normal to" view button).  Then I add the view to the drawing using "Insert → Drawing view → Named".  If the orientation doesn't match a named view, there is still the option to use the model's current view.
I could be the world's greatest underachiever, if I could just learn to apply myself.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
The only thing I can get to work for me is when I zoom right into the end-section of the shaft, and extrude-cut a small, tiny tiny tiny square into the part (which I can hide later), then atleast I can pick a second side to complete the task.
This seems very rudimentary to me...
Would it work to add a sketch with lines to select and orient the view, then hide the sketch?
- - -Dennyd
Dennyd,
   Yesterday, I added a plane to a part, specifically to get it oriented for drawing purposes.
   I clicked on the plane and I clicked the normal-to button.  I went to the drawing and I selected the name view, and I clicked back on the model.  It worked fine!
   The plane is hidden.  I am not sure what would happen if I deleted it.
   Usually, I use relative view.
                        JHG
I could't get that to work either.   I don't know where you see "named view" under the Insert/drawing view/....
In the menu it's INSERT- DRAWING VIEW - MODEL  and then picked which "named view" to wish to create.
Remember...
       "If you don't use your head,
                       your going to have to use your feet."
