Revolve Question
Revolve Question
Revolve Question
I made a simple 2d contour sketch (front plane) and tried to revolve around the centerline contained in the same sketch.  Usually as soon as I choose revolve, it automatically picks the contour and gives me a preview.  This time it did not.  I actually had to place my arrow over the "inside" of the sketch and it highlighted and I was able to make the revolve.  For some reason SW also changed my sketch to a 3D sketch from 2D.
Why does this happen?
RE: Revolve Question
Did you create half the contour of the part or the whole contour around the CL?
Chris
Sr. Mechanical Designer, CAD
SolidWorks 2005 SP0.1
The part has a hole through the center, therefor I created the top half of the part (closed contour) offset from the C/L half the diameter of the thru hole.
I'm in the habbit of picking my axis for the revolve before I go thorugh the action.  I have no clue why it converted it to a 3D sketch.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
I just created a revolve as you said you did and no problem. Can you send a pic of what yours looks like?
Chris
Yes I can, is there a way to include a screen shot with my reply?  I tried "print screen" paste into MS Paint, copy and paste into my reply but will not attach.
cygnas
You have to place the image into a website & use the following code to retrieve into a post:-
[img http://www.yourweb.com/yourfolder/yourpicture.gif]
& all the best.
If you have more than one construction line in your sketch, you either need to have the revolve line selected when you select the revolve command, or need to select it later.  (SWX needs you to tell it WHICH line to revolve about.)
As for the 3D sketch part...no idea.  Are you sure you began as a 2D sketch?
I don't see a Centreline! Did you include one in the sketch?
1) As Arlin pointed out, only one centreline can be selected.
2) You cannot have multiple lines.
3) The sketch must be closed ... no gaps, overlaps or crossed lines.
Get the sketch in Edit mode, go to Tools > Sketch Tools > Check sketch for feature ... to see if a problem exists. Only one problem per analysis is shown, so multiple checks may be in order. More details on this can be found in the Help files under Sketch tools, diagnostics
& all the best.
From what I see, the sketch looks correct. As others said, check to make sure there are no extra lines/gaps/overlaying lines. Only one CL selected.
Chris
Here is the screen shot with FMT.  I did try the following:
Get the sketch in Edit mode, go to Tools > Sketch Tools > Check sketch for feature ... to see if a problem exists. Only one problem per analysis is shown, so multiple checks may be in order. More details on this can be found in the Help files under Sketch tools, diagnostics.  No errors found.
http://img127.exs.cx/my.php?loc=img127&image=revolvefullscreen7sl.png
I would remove the revolve feature, because you selected the contour in the bottom of the tree while making the feature. You don't need to do this. You should only have to pick the centerline.
If you did the check sketch for feature, did it show you and error or give an error? or is that what you mean at the end of your statement? "No errors found"
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
"No Errors Found" is what the response was when I did the check sketch for feature.
1.  Front Plane, insert new sketch.
2.  Create C/L originating from the Origin.
3.  Complete closed profile.
4.  Dimension sketch profile 1/2 the Ø from the C/L.
5.  Make C/L active and choose Insert, Boss/Base, Revolve.
6.  At this point it would not automatically choose the closed profile until I placed my cursor over the closed profile.  When I did this the closed profile became a different color and allowed the selection.
I can email the file to anyone who would like to tear it apart to try and determine how it changed from a 2d sketch to a 3d sketch automatically.
Email it to me. The reason it changes color is because it asking for a contour selection and that's the icon under your feature after you OK'ed it.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
File Sent
When I do a Check Sketch for feature I see "Sketch contains an entity with unsuitable geometry" and it highlights the entity. It's the first line creating the tooth coming from the right.
I deleted and replaced the line - point to point.
Done a check sketch for feature - no problems found
Done the base revolve (didn't pre-select anything) and the file revolved without and a problem.
Scott Baugh, CSWP
www.scottjbaugh.com
FAQ731-376
I will give that check sketch for feature another try.
Thanks Scott.
