Retaining clip
Retaining clip
Hello All,
I think I may be entering the o-ring Pioneering design. Have any of you ever tried to use an o-ring as retaining device (like a c-clip)?
I have a requirement to seal ambient pressure with some ocean spray wash over. I have an antenna with mast that I have to mount, with the electrical RF connection inside of the mast. I would like to use an o-ring as the mechanical retainer for the mast/antenna assembly. My thoughts were to under cut the o-ring groove and have the difference in the under cut in the mating part, so that the o-ring is seat is shared between both parts.
Has anyone ever used this method, what type of force would be required to install/remove the mast/antenna assembly?
Tofflemire
Tofflemire
RE: Retaining clip
RE: Retaining clip
RE: Retaining clip
Thanks for you ideas. I have been directed not to proceed with this design, mostly for the unknown of what force would be required to pull these apart.
Tofflemire
