CAD Translators
CAD Translators
Our department has begun making the switch from IDEAS to Solidworks. Our license agreement with IDEAS runs out this summer.
Has anyone any experience translating from IDEAS/SDRC to Solidworks? There are a few packages out there that claim bi-directional capability for solid models like Elysium. Can translators handle drawings?
OR, should we just hire a summer student?
Your feedback is appreciated.
RE: CAD Translators
I'd hire the summer student...
Bring back the HP-15
www.hp15c.org
RE: CAD Translators
Chris
Sr. Mechanical Designer, CAD
SolidWorks 2005 SP0.1
RE: CAD Translators
When it's unsuccessful, the natives which did not convert seem obvious to me. I try to convert them manually (opposed to automatic recognition) but they still are unrecognized.
QUESTION: Has FeatureWorks been improved in SW2005?
TIA
RE: CAD Translators
For translation service, I highly recommend MathData Services <http://www.mathdata.com>. They got all the toys and will translate and inspect and clean up. Input and output in most CAD and neutral formats, incluing SW and IDEAS.
http://www.EsoxRepublic.com-SolidWorks API VB programming help
RE: CAD Translators
You are in deep. I have been involved with what you are trying to do for many years. There are no true "bi-directional" translators for what you are trying to do. At best you will be able to end up with a dumb model (no history tree) and a non-associated 2d drawing. The best conversion from IDEAS 2d to SW 2d is by processing your IDEAS 2d out as cgm files, reading them back in, and then posting them back out as dxf files to be read into SW. You end up with only vector information, text becomes lines and arcs, but atleast what you end up with is an exact vector replica (no clean-up). For the 3d, did you try posting the model out as a parasolid and then reading it into SW? If you are going to try and send a 3D assembly model, it is going to translate as the last saved configuration in IDEAS. So, you will want to make sure that your asy's and sub-assy's are in the configuration you want. The rest of your configs are lost.
Hope this helps.
RE: CAD Translators
Yes, I tried parasolid. It provided the same dummy solid as an IGES conversion. Is there something I'm missing? Also, IDEAS would only parasolid out a part, it wouldn't handle an assembly.
TIA
RE: CAD Translators
To do the 3D assemblies from the IDEAS assembly environment, you do this:
File menu - Interoperate - find and pick the assembly file - save it as a parasolids.XT file - go to where you saved it and open it SW.
You can also write a script to batch out all of the parts or assemblies in a porject. (NOTE: parts come with assembly exports)
RE: CAD Translators
Also look at www.elysiuminc.com I pretty sure they support IDEAS. I was just talking with them this past week at the SWWC.
Scott Baugh, CSWP
3DVision Technologies
www.3dvisiontech.com
www.scottjbaugh.com
FAQ731-376
FAQ559-716 - SW Fora Users
RE: CAD Translators
Isn't Solid Edge NX/IDEAS/UG "lite" in a similar manner that SW is to CATIA? Wouldn't EDS or SDRC have a format that will commute between the two? and aren't SW and SEdge in a similar price bracket? just a stab in the dark ... but you see where i am going?
/n
RE: CAD Translators
I have to make a choice which format to use when picking the assembly file? ex UGNX
And the type sets to unigraphics xpk which can not be changed back to parasolid.XT. When I pick on a part file I have no problem making an parasolid.XT. What am I doing wrong with the assembly file?
Is the parasolid.XT file better convertet into SW then an iges file made with SW-flavour?
"To do the 3D assemblies from the IDEAS assembly environment, you do this:
File menu - Interoperate - find and pick the assembly file - save it as a parasolids.XT file - go to where you saved it and open it SW."
/C
RE: CAD Translators
The XPK (package) file is the file that UGNX and Solid Edge interoperate with, and what UGNX to UGNX from two different installations (not networked) transfer back and forth. They retain the relationships within UGNX.
You want to use the parasolid file over the IGES file only if your models aren't created with a lot of surface commands, because SW is utilizing a parasolid kernel for modeling. I would recommend using IGES translations for complex surface models, because you can flavor the IGES better.
I have to check my notes, but I belive (will verify) that you can't bring an assembly model, with all the parts separated, using IGES.
To quote nsessions, "I'm just thinking out loud here:
/n"
FYI - SE has a translator just for IDEAS, because they are both UG products. They are not made for bi-directional interoperability though. I have translated IDEAS to SE, and it works well, and keeps the rework time to a minimum.
VicDude
