Surface Area in Parts List
How do I get the surface area of a part to appear in a column in the parts list?
I can see how to put the mass into a column, but surface area is not available despite being calculated in the part.
I have tried setting a sensor, but these don't appear to be made available in the custom properties like I would have expected.
RE: Surface Area in Parts List
--Scott
For some pleasure reading, try FAQ731-376
Create a custom property called "Surface Area" in the model file and give it the value calculated by SE.
You can then add this column to the parts list.
