VBA autocad property
How can i change the patternName property ? When I try to change that property, I've an error which said "Wrong Numbers of arguments".But there is only one argument and I put it.
RE: VBA autocad property
What version of AutoCAD are you using? Could you also post some code to illustrate your problem?
DimensionalSolutions@Core.com
While I welcome e-mail messages, please post all thread activity in these forums for the benefit of all members.
I use AutoCad 2000.
Here is some code :
Dim ObjHatch As Object
Dim HatchObj As AcadHatch
For Each ObjHatch In ThisDrawing.ModelSpace
    If ObjHatch.ObjectName = "AcDbHatch" And ObjHatch.Layer = "2" Then
        If ObjHatch.PatternName = "SOLID" Then
            ObjHatch.PatternName = "ANGLE"
            HatchObj.Evaluate
            ThisDrawing.Regen acActiveViewport
        End If
    End If
Next
In fact I must change all the Hatch who have Solid as PatternName property.I must put a other PatternName but Something wrong.
Thanks for your help
Looking at the Developer help for PatternName, I found that changing this property does not change the pattern type.
How can I change a hatch "Solid" in hatch "ANGLE" ??
The only parameters for the PatternName property is a string.I just change the String but something wrong...
Could you please help me ??
