Detachment
Detachment
Is possible modeling the detachment, after a crisis value, between two different materials?
If it is, what is the procedure to do?
Is all the week wich I try, but nothing!
Thank all!
Zerbo
P.S. sorry for my english!
Thank all!
Zerbo
RE: Detachment
If you want so simulate a crack propagation or material debonding then , the following chapter might be of interest :
ABAQUS Analysis User's Manual
7.9.3 Crack propagation analysis
RE: Detachment
RE: Detachment
For the moment I use elastics material with stress failure, and the two material are connected with a tie constraint, but the results are too far from the real comportament.
Anyone have a solution for resolve my problem?
For example is possible use another constraint type for modeling the debonding?
Zerbo
