Set Screw Materials
Set Screw Materials
Set Screw Materials
Looking for some technical reference (International standard, ASME, etc) for specifying set screw material.
Good practice is for the hardness and material of the set screw to exceed the shaft, so that the set screw bites into the shaft.
Today we are using a 400sst shaft and 400sst set screw. I want to change to a harder material for the screw and need this reference to avoid a whole bunch of verification testing.
RE: Set Screw Materials
Good practice is to not use a ####### setscrew at all.
Pinch bolts, shrink rings, expansion rings, tapered bushings, even many grades of Loctite work better.
Mike Halloran
NOT speaking for
DeAngelo Marine Exhaust Inc.
Ft. Lauderdale, FL, USA
