AutoCAD raster image to Powerpoint
How can you insert an AutoCAD raster image (.dwg) into a Powerpoint presentation?
RE: AutoCAD raster image to Powerpoint
We have found the best way is to export the dwg as a WMF file (WMFOUT) and import the wmf into OLE applications. We use a program called BetterWMF which gives us great control of the WMF output.
"Everybody is ignorant, only on different subjects." — Will Rogers
I have found that the best way for us is:
1) make the Autocad background white
2) resize the Autocad screen until the objects just fit
3) select all the objects
4) go Edit/Copy
5) in Powerpoint, go Edit/Paste Special/Windows Metafile, NOT a link.
This works in Word, etc also.  Changing the background to white is not needed for all styles of PasteSpecial, but for some and for some applications it is needed.
IFRS-
Yep. That's the way I do it too. And the price is right!
C. Fee
