PSV set pressure test fluid
Can anyone please advise how to determine what test fluid should be used to test the set pressure on a PSV. Any help or reference to standards would be appreciated.
RE: PSV set pressure test fluid
Good afternoon,
Check out API RP 527 - I believe that it deals with the testing of relief valves, designed as per API RP 520 and API RP 521.
thanks Wotcha :) i understood the API RP's detailed the test but not the test media (?) Would welcome your thoughts :)
Test media for thermal relief valve
Thread408-29548
thanks for that thread PAN... really appreciated. the application concerned isn't thermal relief but your thread has really clarified things a lot.
the manufacturer of the valve (liquid service) has tested using Nitrogen and the end user has queried this. manufacturer response was "we always test these valves in this way and have done so for xx years". when pressed, there was no reference to any standards and that concerned me even though the manufacturer is a recognised leader.
