V5 specification tree - How to print it?
I'm sure that there must be an easy answer to this, but how do I print the specification tree. I can not find any way to do it
RE: V5 specification tree - How to print it?
forfun
You can also try to save the Assembly as an .txt file.
This will give you the tree structure with expanded nodes.
-Bjod
Open a paint and hold "CTRL" and "V" to paste.
then save in BMP or JPG format.
johnny
I found in Dassault documentation a script which allows you to write the name of selected products in a text file .
' COPYRIGHT DASSAULT SYSTEMES 2001
Option Explicit
' Purpose : Write the name of selected products in a text file.
' Assumptions : A CATProduct document should be active.
' Author :
' Languages : VBScript
' Locales : English
' CATIA Level : V5R7SP3
' Purpose: Build the complete name of a product.
' Inputs : ioProduct Product the product
' Outputs: osName String the complete name
Sub BuildName ( ByRef ioProduct, ByRef osName )
osName = ioProduct.Name
Dim oRoot As Product
Set oRoot = CATIA.ActiveDocument.Product
Dim oCurrent As Product
Set oCurrent = ioProduct
While (oCurrent.Name <> oRoot.Name)
Set oCurrent = oCurrent.Parent.Parent
osName = oCurrent.Name+"\"+osName
Wend
End Sub
' Purpose: Main.
Sub CATMain()
' Initialize
Dim sTitle As String
sTitle = "Write name of selected products"
Dim sExtension As String
sExtension = "txt"
' Create the file environment
Dim oFso As FileSystem
Set oFso = CATIA.FileSystem
Dim oFile As File
Dim oTextStream As CATIATextStream
' Open the output file
Dim iReturnCode As Integer
iReturnCode = vbRetry
While (iReturnCode = vbRetry)
' Retrieve the path from the user
Dim sFilePath As String
sFilePath = CATIA.FileSelectionBox(sTitle, sExtension,
CatFileSelectionModeSave)
If (sFilePath = "") Then
iReturnCode = vbCancel
Else
' Verify the existence of the output file
sFilePath = sFilePath+"."+sExtension
Dim iOverwrite As Boolean
iOverwrite = False
If (oFso.FileExists(sFilePath)) Then
' Ask user if output file exists
iReturnCode = Msgbox("The file "+sFilePath+" already exists
! Do you want to overwrite it ?", vbQuestion+vbAbortRetryIgnore, sTitle)
If (iReturnCode = vbAbort) Then
ElseIf (iReturnCode = vbIgnore) Then
iReturnCode = vbOK
iOverwrite = True
End If
else
iReturnCode = vbOK
End If
' Create the output file
If (iReturnCode = vbOK) Then
On Error Resume Next
Set oFile = oFso.CreateFile(sFilePath, iOverwrite)
If (Err.Number <> 0) Then
Err.Clear
iReturnCode = Msgbox("Cannot Create "+sFilePath+" !",
vbExclamation+vbRetryCancel, sTitle)
Else
Set oTextStream = oFile.OpenAsTextStream("ForWriting")
iReturnCode = Msgbox("Cannot open "+sFilePath+" as a
text file for writting !", vbExclamation+vbRetryCancel, sTitle)
End If
End If
On Error goto 0
End If
End If
Wend
' Write the name of selected products
Dim oSelection As Selection
Set oSelection = CATIA.ActiveDocument.Selection
' Retrieve the selected products
Dim oProduct As AnyObject
Dim sCompleteName As String
While (Err.Number = 0)
Set oProduct = oSelection.FindObject("CATIAProduct")
If (Err.Number = 0) Then
' Write the name
BuildName oProduct, sCompleteName
oTextStream.Write sCompleteName+vbCrLf
End If
Wend
On Error Goto 0
' Clean
Set oFile = Nothing
Set oFso = Nothing
' Report
Msgbox sTitle+" completed !"
End If
End Sub
Fernando
