Weldments and suppression of individual pieces
I have a weldment (.sldprt) and when I try to suppress 2 of the structural members to make a different config. , 2 other unrelated members go with them. I can suppress other items in the same weldment with no problems. Is there a way to see if the 2 pieces that I want to suppress are linked in some way to the others that dissappear with them? The weldment has no welds yet to tie anything together. Can sketch dimensions tie pieces together maybe?
As always thanks in advance........
Cygnas
Cygnas
RE: Weldments and suppression of individual pieces
You could hide the parts instead of using suppress--that will eliminate all this.
If you must use the suppress feature, you'll need to mate the dependent parts independently from the parts you're suppressing. That way, they won't suppress when you suppress the upstream parts.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
Thanks again,
Cygnas
