best stainless for hight temp cooking, open fire
Thanks all for your assistance. I am building a plate holder for my outdoor cooker which can at times break the 1000 degree temperature level and need to know what stainless to use. is 304 and 18-8 OK for the operation. T
RE: best stainless for hight temp cooking, open fire
I've seen a lot of others made with 304 without apparent problems.
Most likely you will be using 304.
It should work fine. Just two tips.
Don't over clean it. The discolored surface is fine.
But at the same time don't leave cooking resuidues on it. There are a lot of chlorides in food and you can get a lot of pitting. Just wash the soft stuff off and leave the heat tint.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
That is one heck of a plate holder if it works at 1000F. Don't use plastic plates.
