ACAD2004 3D SPIRAL
ACAD2004 3D SPIRAL
Hi
I need help to produce a solid object, i design conveyor
systems and create all my drawings in 3D on AutoCad REL 2004
but i am having problems creating a 3D Spiral. I have used
4DSPIRAL.LSP which is great to draw a 3D Polyline and then
extrude a circle along the path to create a spring, but this does not help me to create a spiral with depth. to explain what shape i require: image a flat plate rolled around a drum and pulled upwards to create a orange peel effect. Is there a easy way to produce this object.
Any help would be appreciated
RE: ACAD2004 3D SPIRAL
Thanks if you know....
For the second post... just use the EXTRUDE command and use the PATH option ~ select the circle as your object and the polyline as your path
www.resourcecad.com ~ For your CAD solutions
this .lsp will create a 3D spiral, or actually, a helix.
It creates a polyline which you can extrude along. The results, though, can be surprising. Watch the command prompt to operate.
hope this helps.
sundemon
(defun C:h3(/ c r p n nr ps pb pe Beta dBeta z dz vertex )
(setq c (getpoint "\n Center : "))
(setq r (getdist c "\n Radius : "))
(setq p (getdist "\n Pitch : "))
(setq n (getreal "\n No. of revolutions : "))
(setq nr (getint "\n No. of steps in each round : "))
(setq ps '((0 . "POLYLINE") (100 . "AcDbEntity") (67 . 0) (100 . "AcDb3dPolyline") (66 . 1) (10 0.0 0.0 0.0) (70 . 8) (40 . 0.0) (41 . 0.0) (210 0.0 0.0 1.0) (71 . 0) (72 . 0) (73 . 0) (74 . 0) (75 . 0)))
(setq pb '((0 . "VERTEX") (100 . "AcDbEntity") (67 . 0) (100 . "AcDbVertex") (100 . "AcDb3dPolylineVertex") (10 0.0 0.0 0.0) (40 . 0.0) (41 . 0.0) (42 . 0.0) (70 . 32) (50 . 0.0) (71 . 0) (72 . 0) (73 . 0) (74 . 0)))
(setq pe '((0 . "SEQEND")))
(entmake ps)
(setq z 0.0)
(setq dz (/ p nr))
(setq dBeta (/ (* 2 pi) nr))
(setq Beta 0.0)
(while (<= Beta (* n (* 2 pi)))
(setq vertex (list (+ (car c) (* r (cos Beta)))
(+ (cadr c) (* r (sin Beta)))
(+ (caddr c) z)
(setq pb (subst (append '(10) vertex) (assoc 10 pb) pb))
(entmake pb)
(setq z (+ z dz))
(setq Beta (+ Beta dBeta))
(entmake pe)
(princ)
)de" old))
-Make sure the circle is normal to the 1st segment of the p-line.
-This works & works great. one caution in case it matters- the resulting solid is quite "heavy" in terms of 3d solids resources. Constructing the shape piece by piece is "lighter" but takes longer because of the extra effort (steps) required. This will only really matter if- 1. you are creating a model with MANY solids components, or if 2. your system isn't necessarily as powerful as you'd like, and "heavy" models slow it down appreciably.
This applies primarily to shapes along a path. i realize there's no practical alternative when doing helicals.
Just a little input, that's all.
The other responses are all excellent!
Good luck-
C.Fee
One last question. Is there any way to quickly input my 3D polyline path, i.e. my series of node points, rather that using 3DPOLY and re-selecting every node point?
