Extended Stem Ball Valves
I originally posted this 2 years ago, but never found any manufacturers that offer this type of ball valve without it being a custom build. I'm hoping that something has changed in two years, so here goes.
I am trying to find manufacturers of a bronze body ball valve (nothing fancy; 300 psig WOG HVAC service) that offer extended stems AND an extended body around the stem, so that I can seal my insulation to the body just below the handle. Something like a cryogenic valve, but I only need something that will accommodate about 2 inches of insulation. Some manufacturers offer extended stems, but not an extended body.
When using standard ball valves in chilled water service, if they need to be operated with any frequency, it is almost impossible to maintain a vapor barrier around the stem region.
Any suggestions would be greatly appreciated.
---KenRad
---KenRad
RE: Extended Stem Ball Valves
It is available as a 3-piece valve. Normal metallurgy is steel or stainless, but if you need solder ends you can get those made of Brass. That's not in the book, but the onlt "special" about doing it would be writing up a special BOM. All the pieces exist.
download the catalog: http://www.fcdlit.com/pdf/pb-94-e.pdf
Check the series C84/C99 valve (SS, reasonable price?) from
www.sharpevalves.com
Hopefully, they will decide to market this valve in the US. I've encouraged them to do so, since there does not appear to be anything like it offered by other valve manufacturers. For those of you outside the US, it is the model s.26 and s.96 (www.rubvalves.com).
---KenRad
