Silicon uptake
3
Silicon uptake
Silicon uptake
How does steel absorb silicon for alloying during a melt? What form of silicon is added, and under what conditions?
I hope this is an appropriate question for this forum. Thanks, Jerry
RE: Silicon uptake
I know that FerroSilicon is what we used in the pilot castings lab. I believe the composition was Fe-75%wt Si
Nick
I love materials science!
RE: Silicon uptake
For small heats and test work we added pure Si metal.  The only problem with FeSi is variations in C and B levels.  Lumps of pure Si are redily available as 99.95% or better.
There are a lot of FeSi grades.  You need to know the amount of Si you are trying to add, the impact of other impurities and the thermal effects (exothermic heating).
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
