Mating Gears or cogs!!!
Does anybody know, if it is even possible, how to make gears or cogs, so that they are in a correct mesh, and is it possible to create a mate which alows rotation of one gear and the one mated to it responds by rotating to maintain the correct mesh?
I was thinking a marco might work but I have not been able to make this work!
Any help would be great even if it is just to say that this is not possible!
Thanks in advance
Valintine.
RE: Mating Gears or cogs!!!
If you are using SW05 look under advanced mates.  You'll find gear mates.
Sorry I should have said, I am only using SW01!
Time to upgrade. There are so many more advanced features in 05 vs 01. Otherwise, use mates/write a macro/find a macro.
Chris
Sr. Mechanical Designer, CAD
SolidWorks 2005 SP0.1
I thought that might be the general reply!
Thanks for your help.
