retrieving a submersible pump from a borehole
My guys where installing a pump into a borehole but in the process one of the discharge pipes gave in. The pump collapsed inside the borehore together with seven pipes (size 11/2").The problem we have now is to retrieve the pump and the pipes. The borehore is about 30m deep the inlet pipe to the borehole is 250mm.
Available equipment: Mobile Crane, Chains, Hooks
RE: retrieving a submersible pump from a borehole
Other than digging down 30m you may wnat to drop a miniature video camera and light down the hole to see what is going on and where and how you can attach to the pump/component. Then use the video camera to guide a line and hook? down the hole to attach to something.
GOOOD LUCK
regards
Dave
I'd also talk to a local well driller (e.g. water wells), and see if they have some recovery devices you could use.
Some well drillers are reluctant to lower their multi thousand dollar camera in a hole with other objects in it. But there are now off the shelf cameras sold at fisherman outlets that are less than $500 usd.
Hydrae
