Whats faster fx53, P4 3.6 or two 244's? also does ECC prevent crashes?
I currently run 2002 on xp sp2 and an Athlon 3200 on an A7N8x dlx with 1.5g of 2-2-2-5 ram. I am currently using a MatroxP750 vcard, but either will take from my home comp a vanilla nVidia 6800, or just buy a new 6800 ultra. Not that it's that relevant, but the rest of the specs are another 128mb ATI9200 pci vcard (I run 4 monitors) 2 36g raptors in raid 0, and a 16x burner all in a beautiful Antec P160 case.
I generally work with very intense/large 2d drawings architectural and engineering drawings. Usually there are a dozen or so paperspace tabs/sheets with avg 3-4 viewports each, and 10,000 - 30,000 objects in modelspace. Currently regens, tabs swaps, printing, etc. takes too much time ~5-20 secs. When I was used to really slow, this seemed fast. But now, when I am going, for example, from page to page to page making subtle last minute fixes, I am consistently waiting on the computer (and usually I'm in a hurry at this point). So I'm thinking it is time for an upgrade. Hell, I built the meat of this computer 2 years ago.
So the question is, what is better? An Athlon FX-53, an Intel P4 3.6, or a pair of Opterons 244's. Each of these cpu solutions is ~$500.
I am particularly interested in someone who has run AutoCAD with a pair of 244 or better opterons, as that is what I plan to go with right now. I'm really only interested if you have had or know someone who has had direct comparative experience between them.
I also am interested in knowing if anyone has any opinons on whether registered ram helps prevent AutoCAD Crashes. It seems program crashes are here to stay, but I often wonder if it isn't the RAM and if it is, if Error Correction would fix it. This obviously would tie into the system selection decision as the dual opteron uses mobos with registered ram, and the others do not.
Thanks to all!
Thanks to all!
RE: Whats faster fx53, P4 3.6 or two 244's? also does ECC prevent crashes?
"Everybody is ignorant, only on different subjects." — Will Rogers
Tks-
C. Fee
If you're ever in Houston call me- I'd like to guy you lunch!
Great post! I printed out the link, and plan to use it frequently in conversations on the topic! I frequently attend 1 & 2 day CAD seminars, where these things are debated, often with relatively little certain knowledge on a topic. Usually these conversations take the form of what you can't do with AutoCAD, and how its performance suffers on modern equipment. I love de-bunking such myths, but I try never to comment in areas where my expertise is marginal, hence the questions in MY post. This will be a big help!
Tks-
C. Fee
