Can I do pipe surge analysis using CAESAR
Dear all,
I have CAESAR-II but i am trying to figure out if it is possible to do a pipe surge analysis using it..
Thanks in advance
Thanks in advance
RE: Can I do pipe surge analysis using CAESAR
XHPIPE
Thanks for your reply..
I am looking for a transient flow.. hydraulic anaysis software..
thanks indeed..
- PipeNet from Sunrise Systems
- BossFluids from Paulin Research
- Fathom, Arrow, and Mercury from AFT (Applied Flow Technology).
Richard Ay
COADE, Inc.
However can I strongly recommend HiTrans - see http://www.istec.com.uy/eng/products/hitrans/
This is inexpensive (certainly not true of the others)and easy to use (the others are very comprehensive and powerful so have lots of pitfalls for beginners). I can help you use it and offer some spreadsheets for data analysis if needed. Linking between flow software and Caesar is not easy with most programs, but I believe that Pipenet can do so directly. However expect to pay thousands of dollars per year to lease these powerful programs, whereas hundreds of dollars buys you HiTrans outright! I have validated HiTrans results against Flowmaster and an confident in its answers. However like all technical problems, you need to understand the subject - no software can prevent you putting in garbage and getting garbage in return!
Stuart
