Backwash Pump Control
We are designing for backwash control of a dual media rapid sand filter (18" anthracite/12" sand). We are proposing to utilize a constant speed, 7,500 gpm vertical turbine/lineshaft pump drawing from Clearwell for backwash. Backwash header will have a rate of flow controller (integral venturi/butterfly) to control backwash rate. Also proposing a blow-off on backwash header to prevent media lifting. Do we need a pump control valve on backwash pump (such as ball or cone)? What would be the advantages or alternatives? Are there ball valve size limits?
RE: Backwash Pump Control
Ball or other type of regulating valve would be too expensive for that size. I think that the usual practice (or at least what I have used in such cases) is to install one butterfly valve with electric actuator & positioner on the main delivery pipeline towards filters. Also you need a flow meter to provide control feed-back for valve opening.
