materials appearance
In SW 2005 the shiny material appears as it should. In SW 2004 any of the shiny materials show up as dull colors. Can any body tell me why? Thanks in advance.
RE: materials appearance
I think it might be a change in your direct or ambient light settings.
"I think there is a world market for maybe five computers."
Thomas Watson, chairman of IBM, 1943.
Have you read FAQ731-376 to make the best use of Eng-Tips Forums?
Are you using RealView in 05 and not in 04?
I noticed the default new part template will have a lavender light off to the right side, so if you haven't changed your template, you'll see more specular highlights.  Check your lighting tab and see if there are any differences.
Jeff Mowry
www.industrialdesignhaus.com
Reality is no respecter of good intentions.
