Cannot get PART FILTER - EXCLUDE to work ??
Hi All,
I am having a little problem getting PART FILTER - EXCLUDE to work correctly on an assembly.
I have created a filter called Engine, selected the assembly, then added a - or Exclude filter to remove 85% of what I don't need.
Now I have checked the online docs and the help shows a simple Venn Diagram, which appears to be quite straightforward.
However when I activate my filter the entire engine displays which of course takes some time to display.
If anyone who has used this can offer as suggestions as to what I am doing wrong, or where I might find the answer I would be grateful.
Thanks very much
Best Regards
Dave
