AWS CODE D1.1
AWS CODE D1.1
Does the AWS D1.1 Code provide a guidelines on the frequency of testing welded connections?
thank you?
thank you?
RE: AWS CODE D1.1
If by frequency you mean the extent of testing e.g. 10%, 25%, 100%etc. then the answer is that the extent of testing is as per specifications or as per the code governing manufacture of the particular item under consideration like code for cylindrical vessels, pressure vessels etc.
I hope that my answer is clear and is of help.
Regards and best of luck.
V.V.Vipin
