IR vs. OPEN PLENUM INTAKE RUNNERS
We are experimenting with intake manifold designs on a V-twin engine for the street (7000-8000 rpm). We may need to use two carbs and the question is this:
For the manifold design, would it be better to have individual runners to each cylinder (IR) or an open area behind the carbs (open plenum)?
I have heard theories for both cases. Any experience out there for this one?
Jim
Jim
RE: IR vs. OPEN PLENUM INTAKE RUNNERS
The IR setup uses a carb with different airflow capacity than a plenum type, with the signal so strong that the carb sees airflow signal in both directios such that the carb will meter fuel in the reverse direction and produce a vapor mist above the air horn area. This makes jetting very specific.
In addition, the tuning can be tightly peaked in the RPM range by selecting tract length as a tuning function.
The plenum connection inlet system subdues the IR attributes to a large degree depending on the physical makeup if the inlet system. This has an effect on the carb size and the jetting since both cylinders could share the fuel/air mix.
