Find Macro
Find Macro
Find Macro
Data Sheet contains generic model designations:
AA-A
AA-B
AA-D
AA-BA
How do I get a macro to find "AA-B" and "AA-BA" from my data sheet using values like AA-B1 or AA-BA2C?
Model = "AA-B1"
I tried:
With ActiveSheet.Range("A3:A500")
Set c = .Find(Model, LookIn:=xlValues, LookAt:=xlPart)
and:
For Each c In [A3:A500]
    If c Like Model Then
RE: Find Macro
Try to use the function
InStr([start, ]your cell, "AA-B",compare]) and
InStr([start, ]your cell, "AA-BA",compare])
m777182
RE: Find Macro
I'll give that a try.  I'll need to use a variable for "AA-B" because I have several hundred.  Will InStr work that way.  I may just can the macro and use vLookup.
Roger
RE: Find Macro
A simple method (here searching first 16 rows of column 1)
On a sheet with a Command button, a ListBox and a TextBox, add this code to the Sheet code page:
CODE
Private Sub CommandButton1_Click()
ListBox1.Clear
For a = 1 To 16
If Cells(a, 1).Value Like TextBox1.Text Then ListBox1.AddItem (Cells(a, 1).Value)
Next a
End Sub
To find all cells with AA at the start type AA* in the TextBox and click the commandbutton
To find B in position 2, use ?B*
To find all '2 character only' strings use ??
? replaces a single character and * replaces all remaining characters
Good Luck
johnwm
________________________________________________________
To get the best from these forums read FAQ731-376 before posting
UK steam enthusiasts: www.essexsteam.co.uk
RE: Find Macro
I like that.  It's not what I need but I like it none the less.  I'm using this more like a database.  Once I find the item I need to return it and 4 more pieces of data on the same row.
RE: Find Macro
a thought . . .
will the built-in autofilter feature/capability suffice for your needs?
good luck!
-pmover
RE: Find Macro
What I really will be doing is to block copy a bunch of these items in and then block copy the results back out.  If I have to do one at a time I might as well look it up by hand.
Thanks for the suggestion though.
RE: Find Macro
You can return the other data from the same row easily;
If Cells(a, 1).Value Like TextBox1.Text Then ListBox1.AddItem (Cells(a, 1).Value) & vbTab & (Cells(a, 2).Value)
Of course you can return the items to stuff other than a listbox!
Good Luck
johnwm
