old gasoline
old gasoline
I figured this would be the best place to ask this(these) question which I have pondered so often. Why does gasoline go bad? Also can it be reversed? How long is it recommended to keep gasoline? What do products like Stabil do and how long do they extend the life of the gasoline? Thanks in advance for the insight.
Ben Englund
Ben Englund
RE: old gasoline
Gas formulation is composed of a number of different chemicals in addition to base stock.
These have various rates of evaporation and photo chemical sensitivities. Without getting into chemistry; over time these migrate out of formulation leaveing the heavier content behind as heavy parts, gum and varnish.
This shows up as a very different odor, will not burn in an engine etc.
One can see all these effects from leaving a lawn mower with gas in the tank for a year and trying to start it the next season.
Keeping gas long term is best done in an air tight, light tight containers with some additive special for extending gas life but in no case go over a year, especially if stored for emergency generator use where it may not be used very often before being replaced.
RE: old gasoline
RE: old gasoline
So I guess storing gasoline for decades is out.....
Ben Englund
RE: old gasoline
Also will nonoxygenated gasoline last longer than regular gasoline?
thanks
Ben Englund
RE: old gasoline
RE: old gasoline
Normal gas can oxidise if exposed to air, and different components will evaporate at different rates leaving the fuel with a higher concentration of the less volatile fractions, however, if kept in a sealed, full drum, it is fairly stable.
2 stroke contains oil. The oil reacts with the octane boosters, and reduces the octane of the fuel and the lubricity of the oil mix. If you get more evaporation of the fuel than the oil, it also ends up oil rich, enhancing lubricity, but further compromising octane. This often gives no real problem, but can result in extra wear, and can result in detonation, which can then quickly destroy an engine
pat pprimmer@acay.com.au
RE: old gasoline
RE: old gasoline
RE: old gasoline
RE: old gasoline
RE: old gasoline
in gasoline, or two-stroke fuel, increases,
the octane would increase since combustion of
the fuel would be more difficult. IMHO...
RE: old gasoline
To much and the engine goes lean and sticks a piston from excess heat. Remember that the oil is metered though the carb in most engines along with the gas.
Too little oil and the piston still sticks fast from lack of lube.
This means there is a window that has to be maintained.
In 4 cycle engines, oil in the air/fuel reduces the octane rating of the the "atomized" charge in the chamber at that time and can change with rpm and engine load not to mention carbon deposits that change the process as time goes by.
Then to get deeper into this for both types of engines, one has to deal with plug heat range and ignition timing.
The results of all this can be preignition, and detonation brought on by the effects of the oil.
It becomes quite an education to figure out what is going on at any time. Is it to hot a plug, is it to much oil, is it to much timing etc. So it can get quite involved by using an exhaust gas temp gage etc.
Close records of mix and changes, are needed if this is for hi performance because it gets costly losing engines to often.
RE: old gasoline
I am at home so I don't have the links available
When I am in the office, I will post some links to some research sites that document this.
The best site is NACA, which is the precursor to NASA. It contains a lot of research on aircraft engines in the early part of the 20th century and during WW11
I will see if I can find it vwith google
RE: old gasoline
http://naca.larc.nasa.gov/
RE: old gasoline
http:/
RE: old gasoline
Ben Englund
RE: old gasoline
