Magnetic Stainless Steel 416MX
I have some drawings out for fabrication, with the material specified as stainless steel 416MX. The fabricator came back to me and asked me if I wanted magnetic or non-magnetic. I told him that as far as I know, all 400 series stainles steels are magnetic, and that if I suspect he used 300 series, I would take a magnet to it.
Does this sound like an intelligent conversation? I have been searching Google on magnetic stainless steels, and it seems to be confirming my opinion. The guy I am talking to is a machinist, not an engineer.
Have I sent the job to the wrong place?
JHG
JHG
RE: Magnetic Stainless Steel 416MX
This material will always be magnetic (at room temp.)
I hope that this is a machined part with no brazing, welding or particular surface finish requirements. 416 is a free machining grade and the high S levels raise hell. But it does cut nice.
Corrosion never sleeps, but it can be managed.
http://www.trenttube.com/Trent/tech_form.htm
Kindly inform the machinist that this material is similar to working with AISI Type 410 SS, and see what his response is regarding machining/handling. If you feel comfortable with their response, ask for paperwork to assure that the shop has ordered the correct grade of AISI 416 SS.
Thank you.
The part is to be machined and passivated. I was not planning on heat treat. My Atlas Alloys catalogue lists a yield strength of 110ksi, without specifying the heat treat. It sounds like I need to check up on MATWEB.
I tend just to write STAINLESS STEEEL on drawings, but this time I wanted the strength and I did not absolutely care about corrosion resistance.
JHG
Just asking for 416 will prob. get you normalized or annealed bar at about 40ksi yield and 75ksi tensile. But watch out the minimums are 30/60.
