Special Inspection Guide Spec?
I'm looking for Guide Specification language to incorporate IBC Special Inspections into our project specs (for Earthwork, Steel, Concrete, Masonry, etc.) Are there any references out there?
-JCali
-JCali
RE: Special Inspection Guide Spec?
http://www.ccb.org/docs/ufgshome/UFGSToc.htm
Unfortunatly it still references older codes such as FEMA 302 and TI 809-04. The lists of items requiring special inspection are quite close to current IBC items though. Though 01452 isn't perfect, it will be a good place to start.
If you find a more up to date spec please post it. Thanks.
