Any one know of a computer program or procedure for designing the wet
Any one know of a computer program or procedure for designing the wet well of stormwater pump station to match (as close as possible) pump curves with inflow hydrographs from a 24 hour SCS type storm?
RE: Any one know of a computer program or procedure for designing the wet
Thanks for the reply.
Can I get SWMM from EPA of their web site?
Currently, I use a spread sheet to estimate the inflow using a method similar to SCS's
hydrograph. I plot the inflow hydrograph and treat it like a reservoir problem to estimate flow
rates. I then use haestad's watercad program to evaluate different pumps (I use a reservoir
to simulate the pump station). Watercad allows me to simulate pump on/off scenarios and
different pump curves. I don't know if any one has tried this before but would like some feed
back.
Thanks again for your response.
