Making a spring in UG?
How do you make a sring in UG (NX2)? I thought there was a "spring" feature in NX2.
Thanks.
Jason Misztal
CAD Designer
Marquardt Switches, Inc.
Cazenovia, NY
Thanks.
Jason Misztal
CAD Designer
Cazenovia, NY
RE: Making a spring in UG?
Goto cadpo's web site click on news -> tech-tips ->UG
fourth topic from the bottom is a topic called "fun with law curves" that will tell you all you need to know about creating springs. You can also download sample parts.
Jeremy
Cowski
I am using NX3.
When trying to sweep a rectangular section along a helix it twists.
I cant seem to find an option for picking the helix axis as you described in your post.
Can you help me further?
Dave
I'm 99% confident the vector direction option is still on NX3, its just a matter of where they hid it.
I tried to create it in NX2 but I dont get a dialog box with the option for orientation as you described.
Is there a setting somewhere to turn it on?
Dave
I created springs in NX2 and NX3,it is almost the same.
create a helix,with the parameters you need.(pitch,radius,direction etc..)
sketch a rectangle or square (the cross section of the spring)
sweep the sketch along guide (helix)
select the vector direction same as the helix direction.
Can you describe the geometry? I'm assuming that you are using 1 helix as a guide string; what is your cross section geometry?
I realised I was using 'sweep' instead of 'swept'
Problem solved.
Thanks for your input
Dave
