VSFlexGrid.PrintGrid
I am trying to print the FlexGrid I just created. I know the syntax is:
VSFlexGrid1.PrintGrid
After the .PrintGrid you can specify the title, orientation, ect. I am trying to change the orientation from portrait to landscape and cant figure out how to do it. Thanks in advance for any help.
Brian
Brian
RE: VSFlexGrid.PrintGrid
VSFlexGrid1.PrintGrid(
Then the list of settings will come up tooltip style.
And of course there is the help file, from which:
Syntax
[form!]VSFlexGrid.PrintGrid [ DocName As String ], [ ShowDialog As Boolean ], [ Orientation As Integer ], [ MarginLR As Long ], [ MarginTB As Long ]
Remarks
The parameters for the PrintGrid method are described below:
DocName As String (optional)
Contains the name of the document being printed. This string appears in the printer window's job list and is also used as a footer.
ShowDialog As Variant (optional, default value = False)
If set to True, a printer selection/setup dialog is displayed before the document start printing. The user can then select which printer to use, page orientation etc.
Orientation As Variant (optional, default value = printer default)
Set this parameter to 1 to print the grid in Portrait mode, or set it to 2 to print the grid in Landscape mode. The default setting, zero, uses the default printer orientation.
MarginLR As Variant (optional, default value = 1440)
Left and right margins, in twips. The margins must be equal. The default value, 1440, corresponds to a one-inch margin.
MarginTB As Variant (optional)
Top and bottom margins, in twips. The margins must be equal. The default value, 1440, corresponds to a one-inch margin.
