suitable material for magnisium
hello all,
i have a maginsium bracket to which i want to connect a nipple made of steel or aluminium. which 1 is more suitable? where can i find some info about that?
btw, i am also worried about the thread in the bracket. i don't want to damage it. is that a problem with those metals?
tks
guy
tks
guy
RE: suitable material for magnisium
My prior concern is the bracket. second is the nipple. the mag can live well with the alum?
the environment shouldn't be too humid, because it is well vented. the temperature of the metals can get to more than 150C deg. and through the nipple (and bracket) there will be hot oil running (around 100 deg).
i don't remember the type of alum. i can check it. it is a standard nipple and i have the ms somewhere.
thanks
