stresses on bolts
stresses on bolts
IN a thick walled cylindical reactor subjec to an internal pressure, a flat lid will be attached with 8 bolts.
I would like to calculate the stresses/Strains in the shell, especially radially outside the bolts in the shell in order to understand where to place the bolts and how much shell wall is necessary outside the bolts.
Since it´s cymetrical I´ve created a part of the cylindrical shell consisting of half a hole for the bolt and some shell around it.
What boundary conditions would you use? especially around the hole for the bolt?
In the 3d model, the holes is just a hole without any threads.
RE: stresses on bolts
What do you mean by tie connection?
I can apply constraints and loads as BC.
FOr the "walls of the bolt" I´ve constrained them in the normal direction since it won´t be able to deform in this direction (at least I think so).
FOr the internal shell wall I´ve set the load in the normal direction the the reactor pressure. Since my 3d object only consist one hole and a segment of the shellwall around the hole, Ive constrained the "cuts" in the shell wall.
I don´t know how to apply the facts of the bolt, for eample that it is pre stressed ...
