Very Challenging question, Max Allow. Press Calculation
I am currently applying for the Canadian Registration Number approval. CSA (Canadian Standard Association) asked me to provide strength calculations for all Fittings. This is what I have so far:
1) I have the Material Min. Tensile: 80,000 PSI
Minimum Yield: 30,000 PSI.
2) I am going to use the thinnest shell thickness, e.g.>> t = .25"
3) I am going to use UG 27, 34, 37 for strength calculation.
This is where I need help, how do I apply Min. Tensile of 80,000 psi (material) to the maximum allowable working pressure to the thinest thickness. Is Minimum Tensile Strength = Ultimate Tensile? Please advise.
RE: Very Challenging question, Max Allow. Press Calculation
keep looking for proffesional advise,
I do a lot of things myself but some times it gets complicated and I have yo seek advise.
Good luck with your project.
It must be a valve forum here, so...
GB
