desig table problem?
How can i link dimensions of external parts in a assembly on the design table?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: desig table problem?
BBJT CSWP
Yes, when I try to link dimensions not created in the assembly they don't link, what can i do?
Emerson Bottero
Curitiba PR
Brazil
There is a execel spredsheet already created to handle this functionality. I will dig it up out of my archives and post it.
BBJT CSWP
I found the spredsheet. The problem is I am new to this site and do not know how to post or attach a file. I did however have a note in the file where I found it. Go out on SolidWorks website to their model library. Under API Modeling Utilities it's called
Excel To SolidWorks Link Template - Allow users to easily link cells in Excel to dimensions in SolidWorks.
If you do not have access to model library let me know and I will figure out a wat to get it to you.
I have used this utillity in the passed and it works pretty slick.
BBJT CSWP
Are you tring to drive a part dimension at the assembly stage?
SW doesn't let users control part dimensions at the assembly stage in a design table. That could cause problems down the line. That's why I make configurations of my parts. Then in the DT of the assembly can you control the part, but only by configurtaion name.
Hope I'm understanding you correctly, or I hope this helps,
Scott Baugh, CSWP
George Koch Sons,LLC
Evansville, IN 47714
sjb@kochllc.com
Just wondering if you had a chance to download the excel spreadsheet that I mentioned in my previous reply? I think it will address your the task that you are trying to accomplish.
BBJT CSWP
