Can you edit the format of the REV TABLE
Is there any way to open and edit the revision table itself as a template before it is inserted in a drawing?
TAP
TAP
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Can you edit the format of the REV TABLE
Insert the revision table into a drawing, make the changes that you want then right click and "save as template" will be listed. You can then save the current revision table and use it where ever you want.
mncad
