AutoCAD title block logo
I have created a title block with a graphic (.tga) logo.  It prints out with a box line around it.  I can't find a way to eliminate box.  Does any one have a suggestion. Thanks.
Kelly Lyons, PE
Principal
www.sTrucTure-Tec.com
RE: AutoCAD title block logo
Is the logo an image file that was inserted into autocad through the insert raster image menu?  If so, go to modify, object, image, frames.  You should be able to turn the frame off.  When it is off, you will not see it and it will not print.  You will also not be able to move the image or modify it unless you turn the frames back on.
Scott
Thanks Scott, that was an easy solution.  I appreciate the help!
Kelly Lyons, PE
Principal
